Einleitung
By far the most common fault with headphones is a broken lead or cushion. If the break is within the headphones themselves or at that end of the lead you will need to disassemble them in order to replace the lead or shorten it to eliminate the break.
Was du brauchst
Use two or three fingers slowly pull the cushion.
By feel, locate 4 screws under the foam, 2 each side.
Scrap away just sufficient foam in order to be able to remove the screws, and remove them.
The speaker assembly is now held in the shell just be a number of tabs around the edges. Gently prise it out from these tabs and remove it.
On the right side connection are made via a small printed circuit board. Remove 2 screws in order to remove this for re-soldering or replacement of any of the wires.
Right: Red
Left: Green
Common (Ground): Gold.
Camera used : lumia 520
7 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Hola Buenas, gracias por las fotos y la información. Te quiero hacer una consulta por si me puedes ayudar, quiero instalar un circuito de Bluetooth a los cascos, lo pondría entre el cable de salida del jack y el circuito verde? Supongo que el circuito sirve para unir los cables de ambos altavoces en una sola salida.
Muchas gracias de antemano
