Zum Hauptinhalt wechseln
Disassembling Palm Centro Logic Board
Was du brauchst
  1. Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: Schritt 1, Bild 1 von 2 Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: Schritt 1, Bild 2 von 2
    • Press and slide open the battery cover.
  2. Disassembling Palm Centro Logic Board: Schritt 2, Bild 1 von 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Disassembling Palm Centro Logic Board: Schritt 3, Bild 1 von 1
    • Phone with battery removed
  4. Disassembling Palm Centro Logic Board, Back Housing: Schritt 4, Bild 1 von 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Disassembling Palm Centro Logic Board: Schritt 5, Bild 1 von 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Disassembling Palm Centro Logic Board: Schritt 6, Bild 1 von 2 Disassembling Palm Centro Logic Board: Schritt 6, Bild 2 von 2
    • Remove the SIM card so housing can be separated.
  7. Disassembling Palm Centro Logic Board: Schritt 7, Bild 1 von 2 Disassembling Palm Centro Logic Board: Schritt 7, Bild 2 von 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Disassembling Palm Centro Logic Board: Schritt 8, Bild 1 von 2 Disassembling Palm Centro Logic Board: Schritt 8, Bild 2 von 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Disassembling Palm Centro Logic Board: Schritt 9, Bild 1 von 2 Disassembling Palm Centro Logic Board: Schritt 9, Bild 2 von 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Disassembling Palm Centro Logic Board, Logic Board: Schritt 10, Bild 1 von 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Disassembling Palm Centro Logic Board: Schritt 11, Bild 1 von 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Disassembling Palm Centro Logic Board: Schritt 12, Bild 1 von 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 15-49, Garner Spring 2010 Mitglied von Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - Antwort
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
kelumaruna - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 3,107
