Zum Hauptinhalt wechseln
Disassembling Panasonic GU87 Main Board removal
Was du brauchst
  1. Disassembling Panasonic GU87 Main Board removal, Battery: Schritt 1, Bild 1 von 1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Main Board removal: Schritt 2, Bild 1 von 1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Back cover: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Main Board removal: Schritt 4, Bild 1 von 1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Main Board removal: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Main Board removal: Schritt 6, Bild 1 von 1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  7. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Main Board removal: Schritt 7, Bild 1 von 1
    • Lift the main board over.
  8. Disassembling Panasonic GU87 Main Board removal: Schritt 8, Bild 1 von 1
    • Pry the connector with finger nails.
Abschluss
Van
7 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 2-10, Johann Summer 2010 Mitglied von Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,760
