Zum Hauptinhalt wechseln
Disassembling Panasonic GU87 Main-LCD
Was du brauchst
  1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: Schritt 1, Bild 1 von 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Main-LCD: Schritt 2, Bild 1 von 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Main-LCD, LCD: Schritt 3, Bild 1 von 1
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Main-LCD: Schritt 4, Bild 1 von 1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 Main-LCD, Main Board: Schritt 5, Bild 1 von 1
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 Main-LCD: Schritt 6, Bild 1 von 1
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 Main-LCD: Schritt 7, Bild 1 von 1
    • Pull/pivot the LCD main board as shown in order to remove.
  8. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: Schritt 8, Bild 1 von 1
    • Use tweezers to lift up the main LCD.
Abschluss
Van
7 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 2-10, Johann Summer 2010 Mitglied von Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,200
