Einleitung
Do you have broken parts inside your camera that you don't see guides for? Do you want to see what makes your camera work? Do you need to recycle your camera and want to do it properly? This guide will show you how to completely disassemble your Panasonic LUMIX DMC-LX100.
Was du brauchst
Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
Use a Phillips #000 screwdriver to remove the five 4.5 mm screws located on the bottom of the camera and the top one on the left side, with the lens facing you.
Use a Phillips #000 screwdriver to remove the two 3.5 mm screws, one below the lens and one on the left side.
Use a Phillips #000 screwdriver to remove the 7.1 mm screw from the right side of the camera.
Use a Phillips #000 screwdriver to remove the 2.5 mm screw underneath the viewfinder.
Pull the black plastic piece off of the viewfinder.
Slide out the black plastic piece that acts as a placeholder for an attachable lens on the top of the camera.
Remove the small metal insert that rests beneath the black plastic piece by pulling outward, away from the lens side of the camera.
Use a Phillips #000 screwdriver to remove all four of the 7.1mm screws that are under the metal piece.
Pry off the back of the camera using a spudger starting from the top right side of the LCD screen.
Use a Phillips #000 screwdriver to remove the 7.5mm screw on the top right of the back of the camera that holds the metal backing in place.
Lift the LCD screen away from the device.
Pry off the silver metal backing with a spudger.
Pull out the ribbon cable that attaches the LCD screen to the motherboard.
Remove the LCD screen.
Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector.
Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables.
Use a Phillips #000 screwdriver to remove the two 4.5 mm screws.
Use a Phillips #000 screwdriver to remove the 2.5 mm screw.
Use two fingers to gently pull the viewfinder toward you and out of its housing.
Start at the top of the camera and use the plastic spudger to pry the motherboard out of the camera.
Take the viewfinder you took out earlier and pull the small metal piece off of it.
Use a Phillips #000 screwdriver to remove the three 3.5 mm screws.
Use a Phillips #000 screwdriver to remove the three 3 mm screws.
Gently pull the copper plate towards you to remove it.
Use a Phillips #000 screwdriver to remove the 4 mm screw.
Use a Phillips #000 screwdriver to remove the 4.5 mm screw.
Use a Phillips #000 screwdriver to remove the five 3.5 mm screws.
Use a Torx T3 screwdriver to remove the three 3.1 mm screws.
Use a plastic spudger to gently pull the flash assembly out of its casing.
Gently pull the lens casing out of the camera.
Use a Phillips #000 screwdriver to remove the 4.5mm screw inside the lens housing.
Gently pull the top piece off the camera.
Use a Phillips #000 screwdriver to remove all five 4.1mm screws from the piece you took off in the previous step.
Gently pull the metal cover until it turns 180 degrees.
To remove a knob, remove the screws on the white piece underneath the knob you want to remove with a Phillips #000 screwdriver.
Pull the corresponding white piece off.
Flip the piece over and pull the corresponding black knob off the top of the camera.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
35 Kommentare
Thanks for the effort in compiling this, however even being pretty experienced in precision instrumentation and electronic repair but I encountered some difficulties.
1: To remove the hot shoe cover plate you actually have to lift on the 'forward' end of the plate nearest the lens to un latch and slide it out, not the "back end"
2: The screws are so tightly glued below the hot shoe that they are nearly impossible to remove, I got 3 out but the same front one that appears to be missing in your pictures is stuck fast. The screw that holds the LVF is also glued fast and I believe it's smaller then a 000 phillips.
3: The back metal plate does appear to be glued to the top of the body and no amount of prying seems to loosen it.
It appears Panasonic intended this camera to be disposable and not dissembled. Sad because all of them seem to get dust on the sensor at some point.
Hello,
Thank you for the post.
I would love to add a microphone jack and cannot see the internal microphone wires. Are they part a ribbon (in which case ia m out of luck) or they are independent from a ribbon and accessible?
Hello, I destroyed a wire, the one for the contraol panel (menu, qmenu, arrows, ...) Everything is working fine, but not key are working.
I need the wire to connect to the motherboard.
The ref is : STJ0060SW-9<-->1SW (and 3 special characters)
Where can I buy this ?
Or buy the right keyboard ?
Check out these links, depending on your camera version:
