Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The lens can be safely removed in only seven simple steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the following eleven screws securing the covers to the ZS3 Eleven 3 mm Phillips screws Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown. Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Remove the two LCD board ribbon cables out of their sockets.
    • Remove the two LCD board ribbon cables out of their sockets.
  6. Remove the three black screws that surround the lens.
    • Remove the three black screws that surround the lens.
    • 3mm Phillips screws
  7. Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Disconnect the LCD ribbons gently using the spudger. Disconnect the LCD ribbons gently using the spudger.
    • Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Disconnect the LCD ribbons gently using the spudger.
  8. Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera. Unlock lens mechanism located on the bottom of the device using your fingers. Be sure to not use excessive force to avoid damaging any parts.
    • Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
    • Be sure to not use excessive force to avoid damaging any parts.
Abschluss
Kellen Ericson
10 Reputation
1 Anleitung geschrieben
Cal Poly, Team 13-60, Johann Spring 2013 Mitglied von Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 2,735
