Einleitung
Remove the front cover to access the lens mount, manual and autofocus switch, lens release switch, timer light, and other components.
Was du brauchst
Retrieve your Pentax K200D, the lens mount cover, and required tools.
Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
With the camera turned on, press the pop-up flash button to release the flash.
Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
