Einleitung
This guide will show you how to remove the main camera lens assembly from the camera's frame.
Was du brauchst
Remove the following screws:
Two silver 3.15mm Phillips #00 screws on the right side of the camera
Two silver 2.08mm Phillips #00 screws on the left side of the camera
Remove the two indicated screws on the bottom of the camera:
The screw circled in red is a longer silver 3.15mm Phillips #00 screw
The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
On the front of the camera, in battery case, remove screws indicated:
Two black 2.05mm Phillips #00 screws
Flip the camera over to the backside and remove screws indicated:
The screw circled in red is a longer black 3.00mm Phillips #00 screw
The screw circled in red is a shorter black 2.00mm Phillips #00 screw
Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
Turn camera to front.
Carefully peel off orange wire tape. The tape is glued to the surface indicated.
Lift speaker from holder.
Slowly bend the speaker's wire tape away from the lens assembly. Avoid creasing the tape.
Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera.
Remove copper leads.
Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera.
Remove screw and bracket.
Turn the camera over to the front.
In the following step, you will undo the indicated pegs. PROCEED TO THE NEXT STEP.
Carefully holding the camera, grab the corresponding two points.
Carefully twist the lens assembly away from you. You will be turning your hand clockwise.
Pull lens assembly out.
