Zum Hauptinhalt wechseln
Einleitung
This guide is a prerequisite guide to enable access to features under the top casing for maintenance, repair, and replacement. The top cover encases the top features of the device except the flash and shutter button.
Ersatzteile
Keine Ersatzteile angegeben.
  1. The top cover is one piece encasing the top of the device except the shutter release button and flash.
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel. Using the J0 screwdriver, remove the 6.3 mm screw.
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Locate the next screw by holding the camera upside down with the battery compartment empty and face up. Remove the 6.3 mm screw using a J0 screwdriver.
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  5. The next screw is found in the overhanging piece just above the lens. With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  6. Gently pull off the top cover with your hands by pulling on the tab on the left of the camera. Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Jonathan Diaz
213 Reputation
2 Anleitungen geschrieben
Thank you! Well done sir!
michaelsteele1953 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 497
