Einleitung
In this guide we will be removing the diffuser and the bottom panel of this lamp. This is necessary to access the electronic boards.
Was du brauchst
WARNING Make sure that the power cord of the lamp is unplugged and thus you will not encounter any live wire that tend to hurt...
Stand the lamp up on a table and slightly press on the top gray panel of the lamp.
Take off the bulb from the socket.
By means of a long Philips screwdriver remove the 3 screws that holds the GU5.3 light bulb socket in place.
Lay the lamp down on the table.
With a small flat screwdriver peel off the four rubber feet hiding screws of the lamp bottom panel.
With a long Philips screwdriver remove the four screws from the deep holes of the bottom panel.
With a small flat screwdriver remove the bottom trim by gently levering at the snaps joining it with the command unit.
Locate the 8 plastic snap-ins that hold the diffuser attached to the bottom board of the lamp.
These snap-ins are strongly attaching the diffuse to the bottom board and we may have to break one or two of them in order to separate the diffuser.
Cut one or two plastic snap-ins with a box-cutter.
This will ease to free the other plastic snap-ins without any other risk of damage. Philips must have designed this so that the lamp can not be serviced.
With a small straight screwdriver free the remaining 6 snaps by simultaneously press each snap and pull the diffuser off the bottom board.
Smoothly pull off the main board from the diffuser.
On the figure note the snap-ins in green that remain intact from the previous step and the snap-in in orange that was cut.
With a pair of scissors cut the plastic clip fastener that ties the two wires of the bulb socket.
This step is necessary to loose the main board.
20 weitere Nutzer:innen haben diese Anleitung absolviert.
12 Kommentare
Hi,
The guide was very helpful as I just received such lamp for checking from one friend.
I would make only make one correction: you do not have to cut the plastic snap-ins, none of them.
If you use an IPhone opening toll kit, with those plastic levers as here:
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-000]
then you can open it easy, without any scratches.
im wondering whether its possible to overwrite the wake sounds...
Thank you so much for this guide. Was just about to give up on my lamp and buy and inferior led version when I found this.
These steps also work for the 3740 but the tabs holding the shade on (steps 8-10) are a different style. More like the ones on the bottom trim piece. Had to really work them and muscle that part off.
My ceramic bulb holder is severely corroded to the point where the light will only turn on if you jiggle the bulb. A little sad to see that the wires going to it are permanently attached on both ends. Now that the whole thing is apart. I'm going to see if I can source a new bulb holder and splice it onto the top...
