Einleitung
How to replace the LCD screen if it is broken or cracked.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  7. Locate the black plastic strip under the screen above the white plastic strip.
    • Locate the black plastic strip under the screen above the white plastic strip.
  8. Pull up both sides of the black piece up about a mm.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Abschluss
Dani
21 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-3, Johann Summer 2010 Mitglied von Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,521
