Zum Hauptinhalt wechseln
Polaroid a520 LCD Screen Replacement
Was du brauchst
  1. Polaroid a520 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Polaroid a520 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Polaroid a520 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries from the camera.
  3. Polaroid a520 LCD Screen Replacement, Casing: Schritt 3, Bild 1 von 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Polaroid a520 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Polaroid a520 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 1 von 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Polaroid a520 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Abschluss
Dani
21 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-3, Johann Summer 2010 Mitglied von Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,670
