Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Remove the batteries from the camera.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
    • Locate the black plastic strip under the screen above the white plastic strip.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
    • Unscrew and remove the four (6 mm) screws on the inside casing.
    • Pull the inner casing off of the camera.
    • Unscrew and remove the four (4mm) screws from the logic board.
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
    • Unscrew and remove the two (5mm) screws from the logic board to the far left.
    • Locate the black plastic piece behind the lens.
    • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
    • The piece will not come all the way off; only enough to release the lens.
    • Once the black piece is lifted slide the ribbon out to release the lens.
Abschluss
Dani
Mitglied seit 24.06.2010
21 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-3, Johann Summer 2010 Mitglied von Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 856
