Was du brauchst
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Pull both sides of the black piece upward-about a mm.
Once the piece is lifted carefully slide the screen out of the slot.
Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
Unscrew and remove the two (5mm) screws from the logic board to the far left.
Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
Once the black piece is lifted slide the ribbon out to release the lens.
