Zum Hauptinhalt wechseln
Disassembling Polaroid a520 Logic Board
Was du brauchst
  1. Disassembling Polaroid a520 Logic Board, Battery: Schritt 1, Bild 1 von 2 Disassembling Polaroid a520 Logic Board, Battery: Schritt 1, Bild 2 von 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Logic Board: Schritt 2, Bild 1 von 1
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Logic Board, Casing: Schritt 3, Bild 1 von 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Logic Board: Schritt 4, Bild 1 von 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Logic Board, LCD Screen: Schritt 5, Bild 1 von 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Logic Board: Schritt 6, Bild 1 von 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Logic Board, Logic Board: Schritt 7, Bild 1 von 1
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  8. Disassembling Polaroid a520 Logic Board: Schritt 8, Bild 1 von 1
    • Pull the inner casing off of the camera.
  9. Disassembling Polaroid a520 Logic Board: Schritt 9, Bild 1 von 1
    • Unscrew and remove the four (4mm) screws from the logic board.
  10. Disassembling Polaroid a520 Logic Board: Schritt 10, Bild 1 von 1
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
Abschluss
Dani
21 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-3, Johann Summer 2010 Mitglied von Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 922
