Einleitung
This guide will instruct you to take the left cover off of the camcorder.
Was du brauchst
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
