Zum Hauptinhalt wechseln
Disassembling Ridgid R86034 Housing
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Disassembling Ridgid R86034 Housing, Disassembling Ridgid R86034 Housing: Schritt 1, Bild 1 von 1
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. Disassembling Ridgid R86034 Housing: Schritt 2, Bild 1 von 2 Disassembling Ridgid R86034 Housing: Schritt 2, Bild 2 von 2
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. Disassembling Ridgid R86034 Housing: Schritt 3, Bild 1 von 3 Disassembling Ridgid R86034 Housing: Schritt 3, Bild 2 von 3 Disassembling Ridgid R86034 Housing: Schritt 3, Bild 3 von 3
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. Disassembling Ridgid R86034 Housing: Schritt 4, Bild 1 von 2 Disassembling Ridgid R86034 Housing: Schritt 4, Bild 2 von 2
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. Disassembling Ridgid R86034 Housing: Schritt 5, Bild 1 von 1
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  6. Disassembling Ridgid R86034 Housing: Schritt 6, Bild 1 von 2 Disassembling Ridgid R86034 Housing: Schritt 6, Bild 2 von 2
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
Abschluss
Nathan Hoyt
244 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-5, Amido Spring 2015 Mitglied von Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 77
