Zum Hauptinhalt wechseln
Disassembling Samsung Galaxy S Blaze Whole Device
Was du brauchst
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 1, Bild 1 von 1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 2, Bild 1 von 1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 3, Bild 1 von 2 Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 3, Bild 2 von 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 4, Bild 1 von 1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 5, Bild 1 von 1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 6, Bild 1 von 1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 7, Bild 1 von 1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 8, Bild 1 von 3 Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 8, Bild 2 von 3 Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 8, Bild 3 von 3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 9, Bild 1 von 1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: Schritt 10, Bild 1 von 1
    • All of the parts are seen here.
Abschluss
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jake Best
261 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 11-1, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 735
