Zum Hauptinhalt wechseln
Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone, Phone: Schritt 1, Bild 1 von 3 Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone, Phone: Schritt 1, Bild 2 von 3 Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone, Phone: Schritt 1, Bild 3 von 3
    • This is your phone!
    • Take back case off.
    • Take battery out.
  2. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 2, Bild 1 von 1
    • Remove the 6 screws holing the back plate to the phones frame.
    • PUT THEM IN A SAFE PLACE SO YOU DONT LOSE THEM!
  3. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 3, Bild 1 von 3 Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 3, Bild 2 von 3 Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 3, Bild 3 von 3
    • Insert the Flat head screwdriver into the side of the phone and pry up the back plate.
    • I used two flatheads and used one to hold the section i had pryed up until i could wedge the rest out.
    • You do have to be careful with this step not to use too much force on the back plate, however it held up pretty well on mine.
    • Once you have all the sides pryed loose the back plate should just pop right off!
  4. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 4, Bild 1 von 2 Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 4, Bild 2 von 2
    • Unlatch the 5 ribbon connectors. This will make the motherboard ready to be removed.
    • Simply lift it out!
  5. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 5, Bild 1 von 1
    • Unscrew the final screw up in the top right corner, holding the front facing camera in place
    • Remove the headphone jack (plus attached components) and front facing camera
    • They have sticky tape keeping them attached to the phone, so dont be afraid to pull!
  6. Disassembling Samsung Galaxy s 2 (T-mobile)(T989) Phone: Schritt 6, Bild 1 von 1
    • This is everything i have instructed to take apart, to put back together, just reverse the steps
    • Good Luck!
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Emily
611 Reputation
1 Anleitung geschrieben
4 Kommentare
Not so fun fact: DO NOT PULL ON THE VIBRATOR NEXT TO THE HEADPHONE JACK!
It's not taped. It is adhered using an adhesive that will give with heat. Your hair dryer is your friend...too bad I did not know that first
Baron Kanter - Antwort
My phone was in a polyethelene plastic grocery bag with a 32 oz can of Arizona Iced Sweet Tea. The can had somehow burst inside the bag and the phone was found sometime later completely submerged in the bag filled full of sticky sugar infused beverage! I immediately removed the back cover of the phone and pulled the battery. Amazingly, the battery comparment was remarkable fairly dry but the charging jack and headphone jack had completly filled with fluid.
I DISSAMBLED THE PHONE AND RINSED IN ANHYDROUS ISOPOPYL ALCHOL. ALL PARTS WERE THEN PLACED INTO A METAL COFFEE CAN FILLED WITH PREHEATED SILICA GEL DESSICANT @ 100°F. WHERE THE PARTS WERE ALLOWED TO DEHYDRATE FOR 12 HOURS.
I REASSEMBLED THE PHONE.
After reassembly the phone has been restored to 98% functionality. Every function including various sensors GPS ...EVERYTHING FUNCTIONS NORMALLY EXCEPT.... I HAVE NO MICROPHONE AUDIO!
I can place and recieve calls but nobody can hear me speak. I have dissasembled an reassmbled several time to make sure all connectors have seated properly and have retensioned the plated pressure contact pads inside the outer back frame. I think the contactson the lower bottom are what contact a conductive pad that is where the condenser mic resides? Im not sure where the mic is located they make these thingbs smaller each day! PLEASE HELP AS I NEED PHONE FOR EXPECTED EMPLOYMENT CALL !! I do have bluetooth but its crappy .
dougroundup - Antwort
i have replace my power button 3 times and its the same problem. even when i remove the power button it still vibrates, auto power on etc. does this power button have an power ic thats controls the power button
trex1000 - Antwort
good play iit is so good for all
الفرعون شمس - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 26,931
