Zum Hauptinhalt wechseln
Disassembling Samsung Gravity SGH-T459 Keypad
Was du brauchst
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: Schritt 1, Bild 1 von 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: Schritt 2, Bild 1 von 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: Schritt 3, Bild 1 von 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: Schritt 3, Bild 2 von 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: Schritt 3, Bild 3 von 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: Schritt 4, Bild 1 von 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: Schritt 4, Bild 2 von 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: Schritt 4, Bild 3 von 3
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 736
