Zum Hauptinhalt wechseln
Einleitung
How to remove all speakers on the phone.
  1. Push open the latch and remove the battery. Push open the latch and remove the battery.
    • Push open the latch and remove the battery.
  2. Twist off the antenna. Pop off the transparent cylinder.
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Remove the five screws as shown.
    • Remove the five screws as shown.
  4. Carefully pry the back plate off.
    • Carefully pry the back plate off.
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. Carefully detach golden screen connector. Carefully detach golden screen connector.
    • Carefully detach golden screen connector.
  7. Pop out the logic board with spudger. Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  8. Place the logic board on a clean tray. Place the logic board on a clean tray.
    • Place the logic board on a clean tray.
  9. Remove the hinge on the phone. Put pressure on the spring with the screwdriver to unhinge phone.
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  10. Remove the four screws as shown Use the spudger to pry it open, excessive force may be necessary. Use the spudger to pry it open, excessive force may be necessary.
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  11. Remove the three screws that hold the big speaker Caution: The wires are attached to the screen and should be removed with care. Caution: The wires are attached to the screen and should be removed with care.
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Abschluss
doconnor
25 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-43, Garner Spring 2010 Mitglied von Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,840
