Zum Hauptinhalt wechseln
Samsung SPH-A760 Speakers Replacement
Was du brauchst
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: Schritt 1, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: Schritt 1, Bild 2 von 2
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: Schritt 2, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: Schritt 2, Bild 2 von 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: Schritt 3, Bild 1 von 1
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: Schritt 5, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement: Schritt 5, Bild 2 von 2
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: Schritt 6, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: Schritt 7, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement: Schritt 7, Bild 2 von 2
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: Schritt 8, Bild 1 von 2 Samsung SPH-A760 Speakers Replacement, Speakers: Schritt 8, Bild 2 von 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: Schritt 9, Bild 1 von 3 Samsung SPH-A760 Speakers Replacement: Schritt 9, Bild 2 von 3 Samsung SPH-A760 Speakers Replacement: Schritt 9, Bild 3 von 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: Schritt 10, Bild 1 von 3 Samsung SPH-A760 Speakers Replacement: Schritt 10, Bild 2 von 3 Samsung SPH-A760 Speakers Replacement: Schritt 10, Bild 3 von 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Abschluss
David
25 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-43, Garner Spring 2010 Mitglied von Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 1,942
