Einleitung
How to remove keyboard
  1. Push open the latch and remove the battery. Push open the latch and remove the battery.
    • Push open the latch and remove the battery.
  2. Twist off the antenna. Pop off the transparent cylinder.
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Remove the five screws as shown.
    • Remove the five screws as shown.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Carefully pry the back plate off.
    • Carefully pry the back plate off.
  6. Carefully detach golden screen connector. Carefully detach golden screen connector.
    • Carefully detach golden screen connector.
  7. Pop out the logic board with spudger. Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  8. Place the logic board on a clean tray. Place the logic board on a clean tray.
    • Place the logic board on a clean tray.
  9. Peel off the keyboard.
    • Peel off the keyboard.
Abschluss
doconnor
25 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-43, Garner Spring 2010 Mitglied von Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Mitglieder
12 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,066
