Zum Hauptinhalt wechseln
Einleitung
How to get to and remove the logic board
Ersatzteile
Keine Ersatzteile angegeben.
  1. Push open the latch and remove the battery. Push open the latch and remove the battery.
    • Push open the latch and remove the battery.
  2. Twist off the antenna. Pop off the transparent cylinder.
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Remove the five screws as shown.
    • Remove the five screws as shown.
  4. Carefully pry the back plate off.
    • Carefully pry the back plate off.
  5. Carefully detach golden screen connector. Carefully detach golden screen connector.
    • Carefully detach golden screen connector.
  6. Pop out the logic board with spudger. Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Place the logic board on a clean tray. Place the logic board on a clean tray.
    • Place the logic board on a clean tray.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
doconnor
25 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-43, Garner Spring 2010 Mitglied von Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,366
