Zum Hauptinhalt wechseln
Disassembling Samsung TFT Color YP-T7J USB Connector Dock
Was du brauchst
  1. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: Schritt 1, Bild 1 von 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: Schritt 1, Bild 2 von 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 2, Bild 1 von 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 2, Bild 2 von 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 3, Bild 1 von 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 3, Bild 2 von 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 3, Bild 3 von 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: Schritt 4, Bild 1 von 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: Schritt 4, Bild 2 von 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 5, Bild 1 von 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 5, Bild 2 von 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 1 von 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 2 von 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: Schritt 6, Bild 3 von 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
Abschluss
Dylan Peters
409 Reputation
4 Anleitungen geschrieben
Clemson, Team 14-8, Benson Fall 2013 Mitglied von Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 585
