Zum Hauptinhalt wechseln
Disassembling Sanyo SCP-8100 Back Panel
Was du brauchst
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: Schritt 1, Bild 1 von 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: Schritt 1, Bild 2 von 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: Schritt 1, Bild 3 von 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: Schritt 2, Bild 1 von 2 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: Schritt 2, Bild 2 von 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: Schritt 3, Bild 1 von 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: Schritt 4, Bild 1 von 2 Disassembling Sanyo SCP-8100 Back Panel: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: Schritt 5, Bild 1 von 3 Disassembling Sanyo SCP-8100 Back Panel: Schritt 5, Bild 2 von 3 Disassembling Sanyo SCP-8100 Back Panel: Schritt 5, Bild 3 von 3
    • While removing the back panel, take out the rubber cover on each side.
Abschluss
Yemane
11 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-41, Amido Spring 2013 Mitglied von Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 423
