Was du brauchst
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
In the compartment, move the small notch and push down on the battery to remove it.
Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
Using the spudger, gently pry the rear panel away from the left side.
Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
Using the spudger, gently lift off the front cover of the camera.
