Einleitung
Autofocus bearings were stuck, I could only focus between 0 to 0.5m.
This guide will roughly show you how to reach a part which moves the lens and makes it to zoom and focus.
Was du brauchst
Take the lens away from camera
Unscrew the top part and detach it.
Unjoin cables. Be careful; they're delicate, and easily torn.
Unfasten the screws that hold the circuit board in place, and separate it from the rest of the lens assembly.
Keep unscrewing and removing the parts until you reach what you need to fix.
Zoom bearing can be taken away by unscrewing its srews.
Here is one of the parts which was broken, so I go to camera repair shop, and bought that parts. As this was not the only part broken, I had to leave for additional repair.
When you finish you can put all back together
6 weitere Personen haben diese Anleitung absolviert.
