Zum Hauptinhalt wechseln
Disassembling Sirius Stiletto 100 Front Cover
Was du brauchst
  1. Disassembling Sirius Stiletto 100 Front Cover, Front Cover: Schritt 1, Bild 1 von 2 Disassembling Sirius Stiletto 100 Front Cover, Front Cover: Schritt 1, Bild 2 von 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Front Cover: Schritt 2, Bild 1 von 2 Disassembling Sirius Stiletto 100 Front Cover: Schritt 2, Bild 2 von 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Front Cover: Schritt 3, Bild 1 von 3 Disassembling Sirius Stiletto 100 Front Cover: Schritt 3, Bild 2 von 3 Disassembling Sirius Stiletto 100 Front Cover: Schritt 3, Bild 3 von 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
Abschluss
Trey
80 Reputation
2 Anleitungen geschrieben
Clemson, Team 2-1, Benson Spring 2012 Mitglied von Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,585
