Zum Hauptinhalt wechseln
Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing
Was du brauchst
  1. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: Schritt 1, Bild 1 von 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: Schritt 2, Bild 1 von 3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: Schritt 2, Bild 2 von 3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: Schritt 2, Bild 3 von 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
    Frag FixBot
  3. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: Schritt 3, Bild 1 von 3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: Schritt 3, Bild 2 von 3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: Schritt 3, Bild 3 von 3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
    Frag FixBot
  4. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Opening: Schritt 4, Bild 1 von 1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
    Frag FixBot
  5. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: Schritt 5, Bild 1 von 2 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: Schritt 5, Bild 2 von 2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
    Frag FixBot
  6. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: Schritt 6, Bild 1 von 2 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: Schritt 6, Bild 2 von 2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Trying to do this with the CFS-202, a previous generation. Silly Q from a novice, any recommends on what screwdriver to get for this? The long chasm makes it difficult to get to the screws. Thanks!
Michael C - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 4,467
