Ersatzteile
Kein Ersatzteil erforderlich.
  1. Start here with your Clie in hand.
    • Start here with your Clie in hand.
  2. Unlock the cover slide lock.
    • Unlock the cover slide lock.
  3. Remove cover.
    • Remove cover.
  4. Remove the six case screws on the sides and bottom of the device.
    • Remove the six case screws on the sides and bottom of the device.
  5. Remove the front case.
    • Remove the front case.
  6. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  7. Turn the device over and remove the back case.
    • Turn the device over and remove the back case.
  8. Allow room for the case to come off from the scrool wheel.
    • Allow room for the case to come off from the scrool wheel.
  9. Remove the two screws holding the scroll wheel in place.
    • Remove the two screws holding the scroll wheel in place.
  10. Pull out both sides of the clip to remove the scroll wheel power cable from the device.
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  11. Unscrew the two screws to remove the battery harness.
    • Unscrew the two screws to remove the battery harness.
  12. Pull the power cable from the socket.
    • Pull the power cable from the socket.
  13. Pull out the clips to remove the power cables from the motherboard.
    • Pull out the clips to remove the power cables from the motherboard.
  14. Rotate the motherboard toward you to expose the power cables on the other side.
    • Rotate the motherboard toward you to expose the power cables on the other side.
  15. Pull out the clips to remove the power cables from the motherboard.
Abschluss
Steve
1 Reputation
1 Anleitung geschrieben
James Madison, Team 1-4, Allen Fall 2011 Mitglied von James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Mitglieder
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,307
