Einleitung
This guide shows you how to disassemble a Sony Clie PEG-SL10 through an easy step-by-step process. All you need to perform this repair is a Phillips #0 screwdriver and no additional special skills are required.
This is a precursor to any other repair you may want to do on this device and also allows you to get a good look at its internal workings.
Attached to this guide at the bottom of the page is the Sony Clie PEG-SL10 User Manual.
Was du brauchst
Start by holding your Sony Clie PEG-SL10 face-up in your hand.
Turn your Sony Clie face-up.
Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
Turn the Sony Clie face down and open the back case by prying open the left side of the device.
Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
Pull out both sides of the clip to remove the scroll wheel power cable from the device.
Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
Pull the power cable from the socket located above the upper right side of the battery harness.
Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
Gently pull out the clips to remove the top power cables from the motherboard.
