Zum Hauptinhalt wechseln
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
Was du brauchst
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: Schritt 1, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 2, Bild 1 von 1
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 1 von 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 2 von 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 3 von 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 4, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 4, Bild 2 von 2
    • Use hands to gently pry the front casing away from the camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 2,636
