Was du brauchst
Grip the lower portion of the back of the phone and slide downwards.
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Remove the two Torx screws from below the cover.
These are T5 Torx screws, 8.6mm.
Gently work a spudger or a fingernail between the keypad face and the backplate.
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
Note that only the bottom strut has a tab.
The screws are Phillips, 2.9mm
Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
The screws are Phillips, 2.4mm
Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
Remove the two Torx screws revealed under the grey cover.
The screws are Torx T5, 5.6mm
Remove the black front plate.
Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
Gently release the small grey retaining clips around the outside of the display assembly.
Separate the display assembly from its backplate.
The LCD section is now disassembled.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
