Einleitung
My earbuds got run over a while ago, so let's take the case apart too! I'm hoping I can reuse the circuitry for another project
Was du brauchst
Flip open the cover and insert a thin flathead screwdriver in the seam by the hinge
Rotate the screwdriver just enough to create a gap between the two halves of the case
If this doesn't work very well, try the other side
Insert a spudger or another flathead bit into the new gap
Once you've created a small gap, the lid should come off fairly easily
Run the spudger around the case until the two halves separate
Gently lift the circuitboard off. Not too high; it's still wired to the battery
Now just pull off the battery; it's only held down by a sticky foam pad
