Zum Hauptinhalt wechseln
Disassembling Speak And Spell Case
Was du brauchst
  1. Disassembling Speak And Spell Case, Case: Schritt 1, Bild 1 von 2 Disassembling Speak And Spell Case, Case: Schritt 1, Bild 2 von 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: Schritt 2, Bild 1 von 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Abschluss
bushing
10.247 Reputation
13 Anleitungen geschrieben
Ein Kommentar
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 4,958
