Einleitung
For this guide you will remove six screws in order to remove the back cover.
Was du brauchst
Remove the calculator's protective cover.
Place the calculator face down.
Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
