Zum Hauptinhalt wechseln
Disassembling Toshiba NB205 N330PK Back Panels
Was du brauchst
  1. Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: Schritt 1, Bild 1 von 2 Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: Schritt 1, Bild 2 von 2
    • Using the Phillips #0 in the bit driver, carefully loosen and remove the single 5mm screw.
    • With the retaining screw removed, lift the panel upwards to separate it from the netbook.
  2. Disassembling Toshiba NB205 N330PK Back Panels: Schritt 2, Bild 1 von 2 Disassembling Toshiba NB205 N330PK Back Panels: Schritt 2, Bild 2 von 2
    • To replace the panel, do step 1 in reverse:
    • Align the panel slots in the appropriate grooves and set in place.
    • With the bit driver, replace the screw to secure the RAM panel.
  3. Disassembling Toshiba NB205 N330PK Back Panels: Schritt 3, Bild 1 von 2 Disassembling Toshiba NB205 N330PK Back Panels: Schritt 3, Bild 2 von 2
    • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
    • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
    • The hard drive is located beneath this cover and is now accessible.
  4. Disassembling Toshiba NB205 N330PK Back Panels: Schritt 4, Bild 1 von 2 Disassembling Toshiba NB205 N330PK Back Panels: Schritt 4, Bild 2 von 2
    • To replace the hard drive panel, do step 3 in reverse:
    • Place the panel back in its original position and press down.
    • If the hard drive was removed or replaced during this process, improper installation may prevent the hard drive panel from sitting in the slots properly.
    • With the bit driver and Phillips bit, replace the two retaining screws to secure the cover plate in place.
Abschluss
Mason McCaskill
1.000 Reputation
9 Anleitungen geschrieben
Clemson, Team 14-2, Benson Fall 2013 Mitglied von Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 960
