Zum Hauptinhalt wechseln
Disassembling Toshiba T1960CS for HDD Removal
Was du brauchst
  1. Disassembling Toshiba T1960CS for HDD Removal, HDD Removal: Schritt 1, Bild 1 von 1
    • Pry up cover, remove screw.
  2. Disassembling Toshiba T1960CS for HDD Removal: Schritt 2, Bild 1 von 1
    • Remove screws.
  3. Disassembling Toshiba T1960CS for HDD Removal: Schritt 3, Bild 1 von 1
    • Gently pry out to unsnap top plastic housing.
  4. Disassembling Toshiba T1960CS for HDD Removal: Schritt 4, Bild 1 von 1
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. Disassembling Toshiba T1960CS for HDD Removal: Schritt 5, Bild 1 von 1
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
WayneG
191 Reputation
1 Anleitung geschrieben
Ein Kommentar
The plastic housing does not come off. It seems to be attached to the screen
James Blimthorpe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 3,069
