Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the tire pressure valve.
    • Locate the tire pressure valve.
  2. First, you must release the air.
    • First, you must release the air.
    • To release the air from the tire, press the center spoke in the middle of the air pressure valve.
    • Release air until no more air is being released.
  3. Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel
    • Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel
  4. Now you may separate the tire from the wheel. Be careful pulling the tire from the wheel around the air pressure valve. Be careful pulling the tire from the wheel around the air pressure valve.
    • Now you may separate the tire from the wheel.
    • Be careful pulling the tire from the wheel around the air pressure valve.
  5. To remove the tube, all you need to do is pull the tube from the inner lining of the tire. To remove the tube, all you need to do is pull the tube from the inner lining of the tire.
    • To remove the tube, all you need to do is pull the tube from the inner lining of the tire.
Abschluss
Kaveh Karimiyanha
759 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 1-1, Propen Fall 2012 Mitglied von Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Mitglieder
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
John Sinclair - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 769
