Zum Hauptinhalt wechseln
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
Was du brauchst
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: Schritt 1, Bild 1 von 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 2, Bild 1 von 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 2, Bild 2 von 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 3, Bild 1 von 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 4, Bild 1 von 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 5, Bild 1 von 1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 6, Bild 1 von 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 7, Bild 1 von 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Daniel Kresge
385 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 6
Letzten 30 Tage: 30
Insgesamt: 1,771
