Was du brauchst
Remove Battery, SIM Card, and MicroSD
Remove the four screws located around the edge of the case. They should be very small phillips heads.
Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
