Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you the quickest way to remove the front of the device so you can get to deeper parts of the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device. Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
  2. Remove these seven 11.5 mm screws and place aside.
    • Remove these seven 11.5 mm screws and place aside.
  3. Lift the right side off of the device and place aside.
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
  4. Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
  5. Gently lift up on the indicated tabs to disengage them from the hooks holding them in place. Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
  6. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  7. Lift up the top while firmly sliding it towards the back of the device.
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
  8. Using forceps or fingers, remove the small black wire indicated.
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  9. This step deals with the indicated area of the device. Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture. Gently pull on the cord near its base until it comes free of the restraint.
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
  10. This step deals with the indicated area of the device. Lift the indicated tabs out until the restraint looks like the final picture. Gently pull on the cord until it comes free of the attachment.
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
  11. This step deals with the indicated portion of the the device. Lift the indicated tabs out until they look like the final picture. Gently pull on the cord until it comes free of its restraint.
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
  12. This step deals with the indicated area of the device. Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free. Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  13. This step deals with the indicated area of the device. Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  14. This step deals with the indicated area of the device. Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device. Rotate device 180 degrees and repeat for other side.
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
  15. Wiggle the front gently while pulling it forward until it comes free of the body of the device.
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
NathanB
287 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-1, Regan Spring 2011 Mitglied von Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Mitglieder
Excellent and clear instructions, thankyou. Only trouble is the CD Changer device door is not opening! As I have not actually carried out the Front Panel removal at present I am hoping my problem will expose itself when I complete your instructions in practicality. Thanks again. Denis.
Denis Parker - Antwort
Thanks a lot for the guide! I was able to fix my problem of cassettes playing too slow. You rock!
Jirka Arbter - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 18
Insgesamt: 3,714
