Zum Hauptinhalt wechseln
Disassembling the Blue-Bot
  1. Disassembling the Blue-Bot, Introduction: Schritt 1, Bild 1 von 1
    • In this guide we will take a look at the internals of TTS's Blue-Bot and how we can completely disassemble it.
  2. Disassembling the Blue-Bot, Getting inside the robot: Schritt 2, Bild 1 von 3 Disassembling the Blue-Bot, Getting inside the robot: Schritt 2, Bild 2 von 3 Disassembling the Blue-Bot, Getting inside the robot: Schritt 2, Bild 3 von 3
    • To open the Blue-Bot, remove the Phillips M3 screws and lift up the top cover.
  3. Disassembling the Blue-Bot, Removing the battery: Schritt 3, Bild 1 von 3 Disassembling the Blue-Bot, Removing the battery: Schritt 3, Bild 2 von 3 Disassembling the Blue-Bot, Removing the battery: Schritt 3, Bild 3 von 3
    • On the bottom of the robot, remove the Tri-angle screw.
    • This will reveal the battery that you need to disconnect to remove it.
  4. Disassembling the Blue-Bot, Unglue the LEDs: Schritt 4, Bild 1 von 2 Disassembling the Blue-Bot, Unglue the LEDs: Schritt 4, Bild 2 von 2
    • Now that the cover is off, we have access to the the PCB but before removing it the LEDs for the eyes are glued on the chassis.
    • With a hairdryer or a heat gun, we can soften the glue to remove it easily.
    • You can also remove the glue by force but you have to be careful to not break the LEDs.
  5. Disassembling the Blue-Bot, Unscrewing the PCB: Schritt 5, Bild 1 von 2 Disassembling the Blue-Bot, Unscrewing the PCB: Schritt 5, Bild 2 von 2
    • The next step is to remove the screws holding the PCB to the chassis.
    • Remove the two M3 screws and simply lift up the PCB.
  6. Disassembling the Blue-Bot, Getting the cables out of the way: Schritt 6, Bild 1 von 3 Disassembling the Blue-Bot, Getting the cables out of the way: Schritt 6, Bild 2 von 3 Disassembling the Blue-Bot, Getting the cables out of the way: Schritt 6, Bild 3 von 3
    • Before removing the plastic cover holding the motors we need to remove the PCB cables inserted in it.
    • These cables are very thin and weakly attached to the PCB so you need to remove them one by one and be sure not put too much force on them.
  7. Disassembling the Blue-Bot, Removing the plastic cover: Schritt 7, Bild 1 von 3 Disassembling the Blue-Bot, Removing the plastic cover: Schritt 7, Bild 2 von 3 Disassembling the Blue-Bot, Removing the plastic cover: Schritt 7, Bild 3 von 3
    • Remove the four Phillips M3 screws.
    • Simply lift the plastic cover and remove it.
  8. Disassembling the Blue-Bot, Removing the USB connector: Schritt 8, Bild 1 von 1
    • To remove the USB connector, unscrew the two M3 screws on the side of the connector and lift.
  9. Disassembling the Blue-Bot, Removing the motors: Schritt 9, Bild 1 von 2 Disassembling the Blue-Bot, Removing the motors: Schritt 9, Bild 2 von 2
    • Now that everything is out of the way, you can just lift the motors up as shown.
  10. Disassembling the Blue-Bot, Getting to the Switches: Schritt 10, Bild 1 von 2 Disassembling the Blue-Bot, Getting to the Switches: Schritt 10, Bild 2 von 2
    • Remove the Phillips screw holding the plastic cover to get to the power and speaker switches.
  11. Disassembling the Blue-Bot, Removing the Switches and Speaker: Schritt 11, Bild 1 von 2 Disassembling the Blue-Bot, Removing the Switches and Speaker: Schritt 11, Bild 2 von 2
    • You can now remove the switches and the speaker from the chassis.
  12. Disassembling the Blue-Bot, Conclusion: Schritt 12, Bild 1 von 1
    • This concludes the Blue-Bot disassembly with all its different parts shown here.
    • Note: The only way to remove the battery connector is to remove solder on the PCB attaching the cable and pass the able through the hole.
Abschluss
To reassemble your device, follow these instructions in reverse order!
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 40
Insgesamt: 329
