Zum Hauptinhalt wechseln
Disassembling the Circuit Board
Was du brauchst
    1. Disassembling the Circuit Board, Cracking the Case: Schritt 1, Bild 1 von 1
      • Turn the device upside down so that the three rubber pads are facing up.
      Frag FixBot
      Kommentar hinzufügen
    2. Disassembling the Circuit Board: Schritt 2, Bild 1 von 1
      • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
      Frag FixBot
    3. Disassembling the Circuit Board: Schritt 3, Bild 1 von 1
      • Remove the heated rubber pad with a plastic opening tool.
      • Repeat steps 2 and 3 for the two remaining rubber pads.
      Frag FixBot
    4. Disassembling the Circuit Board: Schritt 4, Bild 1 von 2 Disassembling the Circuit Board: Schritt 4, Bild 2 von 2
      • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
      Frag FixBot
    5. Disassembling the Circuit Board: Schritt 5, Bild 1 von 3 Disassembling the Circuit Board: Schritt 5, Bild 2 von 3 Disassembling the Circuit Board: Schritt 5, Bild 3 von 3
      • Open the device along its seam.
      • Be careful when separating the device because there are wires connecting the two seperate halves.
      Frag FixBot
    6. Disassembling the Circuit Board: Schritt 6, Bild 1 von 1
      • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
      Frag FixBot
    7. Disassembling the Circuit Board: Schritt 7, Bild 1 von 2 Disassembling the Circuit Board: Schritt 7, Bild 2 von 2
      • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
      Frag FixBot
    1. Disassembling the Circuit Board, Circuit Board: Schritt 8, Bild 1 von 2 Disassembling the Circuit Board, Circuit Board: Schritt 8, Bild 2 von 2
      • Remove the three 1 cm T-10 Torx screws.
      Frag FixBot
    2. Disassembling the Circuit Board: Schritt 9, Bild 1 von 1
      • Carefully press out the white base tube and push up on the circuit board.
      • Note that there is a small wire connecting the circuit board to the base.
      Frag FixBot
    3. Disassembling the Circuit Board: Schritt 10, Bild 1 von 2 Disassembling the Circuit Board: Schritt 10, Bild 2 von 2
      • Pull the white wire out of the hot glue.
      Frag FixBot
    4. Disassembling the Circuit Board: Schritt 11, Bild 1 von 3 Disassembling the Circuit Board: Schritt 11, Bild 2 von 3 Disassembling the Circuit Board: Schritt 11, Bild 3 von 3
      • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
      • Remove the heat sink; it should detach from the bottom of the device.
      Frag FixBot
    5. Disassembling the Circuit Board: Schritt 12, Bild 1 von 3 Disassembling the Circuit Board: Schritt 12, Bild 2 von 3 Disassembling the Circuit Board: Schritt 12, Bild 3 von 3
      • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
      • Turn the device so that the base tube is on top.
      • Remove the base tube by pulling up.
      • May need to cut the rubber adhesive between the base tube to the circuit board.
      Frag FixBot
Abschluss
To reassemble your device, follow these steps in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 9-28, Maness Winter 2014 Mitglied von Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 45
Insgesamt: 5,409
