Zum Hauptinhalt wechseln
Disassembling the Circuit Board
Was du brauchst
  1. Disassembling the Circuit Board, Cracking the Case: Schritt 1, Bild 1 von 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Disassembling the Circuit Board: Schritt 2, Bild 1 von 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Disassembling the Circuit Board: Schritt 3, Bild 1 von 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Disassembling the Circuit Board: Schritt 4, Bild 1 von 2 Disassembling the Circuit Board: Schritt 4, Bild 2 von 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Disassembling the Circuit Board: Schritt 5, Bild 1 von 3 Disassembling the Circuit Board: Schritt 5, Bild 2 von 3 Disassembling the Circuit Board: Schritt 5, Bild 3 von 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. Disassembling the Circuit Board: Schritt 6, Bild 1 von 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. Disassembling the Circuit Board: Schritt 7, Bild 1 von 2 Disassembling the Circuit Board: Schritt 7, Bild 2 von 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. Disassembling the Circuit Board, Circuit Board: Schritt 8, Bild 1 von 2 Disassembling the Circuit Board, Circuit Board: Schritt 8, Bild 2 von 2
    • Remove the three 1 cm T-10 Torx screws.
  9. Disassembling the Circuit Board: Schritt 9, Bild 1 von 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. Disassembling the Circuit Board: Schritt 10, Bild 1 von 2 Disassembling the Circuit Board: Schritt 10, Bild 2 von 2
    • Pull the white wire out of the hot glue.
  11. Disassembling the Circuit Board: Schritt 11, Bild 1 von 3 Disassembling the Circuit Board: Schritt 11, Bild 2 von 3 Disassembling the Circuit Board: Schritt 11, Bild 3 von 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. Disassembling the Circuit Board: Schritt 12, Bild 1 von 3 Disassembling the Circuit Board: Schritt 12, Bild 2 von 3 Disassembling the Circuit Board: Schritt 12, Bild 3 von 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
Abschluss
To reassemble your device, follow these steps in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 9-28, Maness Winter 2014 Mitglied von Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 4,636
