Zum Hauptinhalt wechseln
Disassembling the Ematic Genesis
Was du brauchst
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: Schritt 1, Bild 1 von 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: Schritt 1, Bild 2 von 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: Schritt 1, Bild 3 von 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: Schritt 2, Bild 1 von 3 Disassembling the Ematic Genesis: Schritt 2, Bild 2 von 3 Disassembling the Ematic Genesis: Schritt 2, Bild 3 von 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: Schritt 3, Bild 1 von 1
    • Remove back plate from screen plate and lay both down flat next to each other.
Abschluss
Baylor, Team 4-3, Williams Spring 2015 Mitglied von Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 313
