Zum Hauptinhalt wechseln
Disassembling the Garmin eTrex Vista-H Outer Case
Was du brauchst
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: Schritt 1, Bild 1 von 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 2, Bild 1 von 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 3, Bild 1 von 2 Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 3, Bild 2 von 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 4, Bild 1 von 2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 4, Bild 2 von 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 5, Bild 1 von 3 Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 5, Bild 2 von 3 Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 6, Bild 1 von 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 7, Bild 1 von 2 Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 7, Bild 2 von 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Ryan Green
93 Reputation
1 Anleitung geschrieben
Cal Poly, Team 21-30, Regan Fall 2010 Mitglied von Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 5,025
