Zum Hauptinhalt wechseln
Disassembling the HP Pavilion tx2500 Bezel
Was du brauchst
  1. Disassembling the HP Pavilion tx2500 Bezel, Screen Rotator: Schritt 1, Bild 1 von 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. Disassembling the HP Pavilion tx2500 Bezel: Schritt 2, Bild 1 von 2 Disassembling the HP Pavilion tx2500 Bezel: Schritt 2, Bild 2 von 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. Disassembling the HP Pavilion tx2500 Bezel: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. Disassembling the HP Pavilion tx2500 Bezel: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. Disassembling the HP Pavilion tx2500 Bezel: Schritt 5, Bild 1 von 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. Disassembling the HP Pavilion tx2500 Bezel: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. Disassembling the HP Pavilion tx2500 Bezel: Schritt 7, Bild 1 von 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. Disassembling the HP Pavilion tx2500 Bezel: Schritt 8, Bild 1 von 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. Disassembling the HP Pavilion tx2500 Bezel: Schritt 9, Bild 1 von 2 Disassembling the HP Pavilion tx2500 Bezel: Schritt 9, Bild 2 von 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. Disassembling the HP Pavilion tx2500 Bezel: Schritt 10, Bild 1 von 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. Disassembling the HP Pavilion tx2500 Bezel: Schritt 11, Bild 1 von 2 Disassembling the HP Pavilion tx2500 Bezel: Schritt 11, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. Disassembling the HP Pavilion tx2500 Bezel: Schritt 12, Bild 1 von 1
    • Gently lift up and remove the screen.
  13. Disassembling the HP Pavilion tx2500 Bezel, Bezel: Schritt 13, Bild 1 von 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: Schritt 13, Bild 2 von 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: Schritt 13, Bild 3 von 3
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
  14. Disassembling the HP Pavilion tx2500 Bezel: Schritt 14, Bild 1 von 2 Disassembling the HP Pavilion tx2500 Bezel: Schritt 14, Bild 2 von 2
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
  15. Disassembling the HP Pavilion tx2500 Bezel: Schritt 15, Bild 1 von 2 Disassembling the HP Pavilion tx2500 Bezel: Schritt 15, Bild 2 von 2
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
  16. Disassembling the HP Pavilion tx2500 Bezel: Schritt 16, Bild 1 von 1
    • Gently remove the bezel from the system board.
Abschluss
Sarah Naiser
324 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 1-4, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 1-4, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 756
