Einleitung
The Mobius ActionCam is a small, durable video recorder often used as a helmet or dash camera.
The disassembly is very simple and individual components are easy to replace.
Was du brauchst
Remove the lens cap.
Remove the SD card by pressing down on the card until you hear a click, then releasing.
Use a Phillips #00 screwdriver to remove both screws on the bottom of the case.
Use a box cutter or knife to split the quality control seal on the front of the device.
Pull the casing apart near the lens.
Slide back the bottom half of the case to disengage the clips holding the casing halves together.
Gently remove the bottom of the case and place it alongside the device.
Locate the camera module.
Grab the sides of the camera module and gently pull upwards to free it from the case.
Use your finger to pull up the black tab on the rear of the ribbon cable connector.
Slide the ribbon cable out of the connector to remove the camera module.
Grab the battery plug with a pair of small needle nose pliers. Gently pull upwards to disengage the connectors.
Lift up one end of the battery. Slowly pull the battery off the adhesive backing.
Locate the 3 screws securing the circuit board to the casing.
Use a Phillips #1 screwdriver to remove the screws.
Lift the edge of the circuit board up. Slide the circuit board out of the casing.
Remove the interface buttons from the top of the case.
Remove the circuit board backing material.
3 weitere Personen haben diese Anleitung absolviert.
